It is currently Sat Nov 21, 2026 4:25 am
 Post subject: Down in the Hole?
PostPosted: Tue Jun 30, 2009 5:18 am
Is there a year to year difference in the "down in the hole" distance for 225 blocks? What is a typical number? What is the largest and what is th e smallest number anyone has seen on a stock block?
The reason why I ask, is I am measuring 0.129 ('72) on a stock block. The others I have seen are much larger than that.
Thanks
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Tue Jun 30, 2009 7:12 am
Bob
Ive seen .1 to .2 I would say about .180 is average. Most of the block I have are .180-.187.
Hope this helps,
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Jun 30, 2009 12:52 pm
Sounds like that block was milled. The least I have measured is about 0.170".
 Post subject: Dart
PostPosted: Tue Jun 30, 2009 1:38 pm
The block in Ryan's Dart (1972 block) was -140 before we milled it.
Rick
PostPosted: Tue Jun 30, 2009 8:05 pm
Tore down a 300 mile professionally rebuilt motor cause it sat for five years,front cyl was .170 down,rear was .145 ,,deck had a slant to it.My machinest couldnt belive how bad it was,had to be prior work,got them all straight now,Mark
PostPosted: Wed Jul 01, 2009 4:04 am
I have seen that before. Certain mills will not accept a Slant block in a way that the deck comes out flat.
PostPosted: Wed Jul 01, 2009 1:24 pm
Explain? Kind of odd to say that. Gonna have to be flat and parallel WITH crankshaft bore line or the machine shop is fired.
Cheers, Wizard
PostPosted: Wed Jul 01, 2009 5:37 pm
Mike ran into it with a shop he used for decking a block. The fixture the machine had for mounting the block held one end slightly higher than the other. You could not tell with the naked eye, but Mike caught it when checking deck height on the pistons before final assembly. :o
PostPosted: Wed Jul 01, 2009 6:51 pm
My machinist actually put a piece of paper under the front of the block after he got it real close to get it perfect,he is a friend and let me watch,was off a little sideways also,mark
PostPosted: Wed Jul 01, 2009 7:04 pm
I cant find my notes for the measurements, but my #6 piston is down more than my #1...also the head I have from a completely different engine- the #6 chamber cc's less than the #1 chamber, oddly, the difference in the combined volumes equals out. Hehe, a slant-slant six....go figure :roll:
<img src="http://farm4.static.flickr.com/3173/2992308402_5481afb26e_t.jpg">
PostPosted: Wed Jul 01, 2009 7:11 pm
So does the fixtures is slightly worn on one side or the engine block is springy on one end? What about the "bed" that everything are mounted to?
Machining the diesel block is more critical as deck had to be absolutely parallel with the crankshaft center, even I had a note asking to check the rebuilt head deck for parallel-ness with the camshaft bore if head is for diesel also.
Cheers, Wizard
PostPosted: Thu Jul 02, 2009 4:01 am
I am curious now. :roll:
When checking to see if #1 cylinder is down in the hole the same as #6 cylinder, do you use a different piston/rod combination to check each or use the same piston and rod?
If there is a slant to the decking is it always #1 to #6 or #6 to #1 sloped (most depth to least depth)?
bwhitejr
0.090 Shaved Head
PostPosted: Thu Jul 02, 2009 6:23 am
Bob
I use the same piston to mock it all up. Most people check the deck before they disassemble the engine. That tells them how much to take off.
As for 1-6 or 6-1 I guess it would depend on which end they put where on the machine and how off the table is.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Jul 13, 2009 4:35 am
Well, I finally got a depth micrometer and measured my block. I was getting different readings depending on where I measured.
225 Rod with stock piston (no rings)
Driver Side of block 0.172
Rear of cylinder 0.17075
Passenger side of block 0.16875
Front of cylinder 0.17025
Dead center of cylinder 0.17925
198 Rod with stock piston (no rings)
Driver side of block 0.1385
Rear of cylinder 0.1395
Passenger side of block 0.1450
Front of cylinder 0.1435
Both pistons were pitted somewhat, so that accounts for the center being lower.
The good news is the sum of the 225 down in the hole measurement and the 198 above deck measurement comes out very close to the difference in the rod length if you average the measurements for both cases.
So, which measrement would be the more accurate one? It seems the one at the rear of the cylinder should be the most accurate, since there are no rings on the piston.
Thoughts?
bwhitejr
0.090 Shaved Head
PostPosted: Mon Jul 13, 2009 6:15 am
Bob
Depends on what you are trying to do. If you are going for Zero deck height then use the smallest number. If calc. the volume for compression then the average. Remember it may change by .005 or so when it get machined.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
