| Where can I get a clutch or PP to fit a slant 6?? https://slantsix.org/forum/viewtopic.php?t=3619 |
| Author: | Michael Harley Glass [ Wed May 15, 2002 11:49 am ] |
| Post subject: | Where can I get a clutch or PP to fit a slant 6?? |
Where can I get a high performance clutch and pressure plate assembly for my slant six powered '71 Demon??? Demonboy71@yahoo.com |
| Author: | Michael Harley Glass [ Wed May 15, 2002 11:51 am ] |
| Post subject: | Re: Where can I get a clutch or PP to fit a slant |
: Where can I get a high performance clutch and : pressure plate assembly for my slant six : powered '71 Demon??? Remember I need a high performance assembly ready to be drag raced... Demonboy71@yahoo.com |
| Author: | Dart270 [ Wed May 15, 2002 2:07 pm ] |
: Remember I need a high performance assembly : ready to be drag raced... Check out Mcleod Industries (www.mcleodind.com). They can set you up with a 10" setup for your stock flywheel. Info below. 714-630-2764 714-630-5129 FAX 714-630-3668 Tech Service 1600 Sierra Madre Circle Placentia, CA 92870 Cheers, Lou |
| Author: | Doc. [ Wed May 15, 2002 4:02 pm ] |
: Remember I need a high performance assembly : ready to be drag raced... The 10 inch set-up will bolt right in and can be made plenty stiff for a SL6. There are lots of custom clutch builders out there, call around. (see the link below for the shop I use out here in California) Local parts store can order the pressure plate as APRA p/n 351525 or 361525, the disc is a little harder to find for the Mopar 23 spline (# 3082??) DD Jump to another Message |
| Author: | upnover [ Thu Aug 22, 2019 3:04 pm ] |
| Post subject: | Re: Where can I get a clutch or PP to fit a slant 6?? |
south bend clutch |
| Author: | Dart270 [ Thu Aug 22, 2019 5:19 pm ] |
Thanks for posting, and welcome to the site, Mr. Upnover. Do you have experience with South Bend Clutch? Looks like a serious place... Lou |
| Author: | Greg Ondayko [ Thu Aug 22, 2019 5:32 pm ] |
Some discussion on the topic here: http://www.slantsix.org/forum/viewtopic ... nd#p479333 Greg |
