It is currently Fri Nov 13, 2026 10:40 am
PostPosted: Sat Jul 18, 2009 5:08 pm
when changing to an electric radiator fan,,what are folks using for an on-off temp switch for the fan?
found this at summit http://www.summitracing.com/parts/PRM-1 ... mage=large, looks like this mounts in a cup plug,, if so may not fit a slant, any suggestions?
thanks
PostPosted: Sat Jul 18, 2009 5:21 pm
I use the adjustable one on my truck........
Adjustable_Temp_Switch
Also wire it to drive a relay, not the direct load of the fan.
PostPosted: Sun Jul 19, 2009 7:32 am
On your truck, mine is a 83 D-150,, where did you place the sensing bulb,
in the coolant in the radiator? or is this an external mount?
If in the radiator, did you braze in a fitting to receive the bulb?
for the fan / relay combo,, I got a fan and power control module from a 94 Caravan, with that I'll have separate relays for high / low speed fan, AC compressor relay interface...
thanks
PostPosted: Sun Jul 19, 2009 8:36 am
Looks like the probe must slip inside the upper radiator hose, is my thought correct?
If so any problem getting it to seal?
66 Valiant, 225.
84 Van, 225.
71 Maxi-Van, 318
60 Valiant wagon, 225
87 Maxi-Van, 318 4spd
PostPosted: Sun Jul 19, 2009 1:10 pm
The probe is external. It's next to the upper tank where the hose enters.
With an adjustable control, it doesn't have to be in the water as you can compensate for the slightly lower temp the probe sees...............
PostPosted: Sun Jul 19, 2009 1:40 pm
Same switch I used. Works great.
11.02 @ 120.56
Chassis dyno
PostPosted: Sun Jul 19, 2009 1:50 pm
Which one,
Mine or DadTruck's ?
PostPosted: Sun Jul 19, 2009 5:24 pm
so,, how do you affix the temp probe to the exterior of the radiator,,
epoxy??
thanks
PostPosted: Sun Jul 19, 2009 5:26 pm
Which one,
Yours. :D
The tension from the fins holds the probe in place. Mine has been in for 2 years now.
11.02 @ 120.56
Chassis dyno
PostPosted: Sun Jul 19, 2009 7:40 pm
epoxy??
thanks
I used the rubber backed tube clamps
sort of like these: http://www.imperialinc.com/grp137.shtml
Clamps around the body and holds it in place.
Attach to angle bracket, fan shroud, whatever works for you.........
PostPosted: Mon Jul 20, 2009 4:33 pm
well I got more than a few workable ideas out of this post,, thanks to all, this is great forum.
PostPosted: Tue Jul 21, 2009 5:22 pm
I use the one emsvitil shows. I just zip tied mine to the rad core.
