| real quick bellhousig question... https://slantsix.org/forum/viewtopic.php?t=36210 |
| Author: | tmj91 [ Fri Jul 10, 2009 6:41 am ] |
| Post subject: | real quick bellhousig question... |
i have an A-903 transmisson in my 64 dart now..if out an A833 will i be able to use the same bellhousig? this statement in the aricle section confuses me..... Quote: Slant Six owners have two bell housing options to mate G/RG blocks to 833s. The original 1964-66 Slant Six four speed bell housing is a great candidate and accepts any A-833 with a 4.35" IBR profile. These units were all cast iron. While these bell housings are becoming increasingly hard to come by, the inspection plate, dust shield, clutch fork, and fork boot can all be swapped-over from a Sixties G/RG with an A-903 three speed. The casting numbers for the early cast iron bell housings are 2463025, 2463027, and 2468431
| Author: | Joshie225 [ Fri Jul 10, 2009 7:01 am ] |
If your existing bellhousing is original to your car, no, it will not accept the A833. Only the original cast iron 4-speed bellhousing and the late model bell with multiple bolt patterns work with the A833. The article refers to the parts from your existing bellhousing that you can use with the cast iron 4-speed bellhousing. Namely the clutch fork, boot and dust shield. |
