| Bunch of questions https://slantsix.org/forum/viewtopic.php?t=36247 |
| Author: | ESP47 [ Sun Jul 12, 2009 8:29 pm ] |
| Post subject: | Bunch of questions |
I'm reading the 4 speed article and running through the forum and it's a lot to take in at once. I'm pretty much a newbie and have never messed with an 833 or anything. But I'd really like to put a 4 speed on my new 68 Barracuda and just have a few questions. Right now it has a 3 on the tree. Are 3 on the tree pedals the same as 4 speed pedals, or can they be used with an a-833 anyway? Also, what year parts should I get, such as tranny, floor hump, bellhousing, flywheel etc that will bolt on to this thing to make it the easiest installation possible? I'd just like to get a list going so I know what to look for while I search for parts. Thanks guys. |
| Author: | slantsixlancer [ Thu Jul 16, 2009 11:29 pm ] |
I did this swap in a 62 a body and it bolted right up..except |
| Author: | slantfin [ Fri Jul 17, 2009 7:10 am ] |
It should be a lot easier with your '68. Same pedal etc., I just had to get a different yoke, and install a transmission hump in my '67. Get a car trans and not a truck one. Just measure the overall length of the 3-speed, and match it to a 4-speed. The other issues are the input bearing retainer has to match your bellhousing (mine came from Brewer) www.brewersperformance.com , and I had to swap the flywheel for some reason I forget now. Getting old. |
| Author: | SlantSixDan [ Fri Jul 17, 2009 7:10 am ] |
The swing pedal assembly is the same, yes. Almost everything else is different. |
| Author: | slantfin [ Fri Jul 17, 2009 9:52 am ] |
Quote: I had to swap the flywheel for some reason I forget now. Getting old. Just remembered, that was for a '75 engine swap. Nevermind, as Kurt Cobain might have said.
