It is currently Fri Nov 20, 2026 10:25 am
PostPosted: Thu Jul 16, 2009 12:30 pm
Trying to fix the vacuum amplifier in 1976 Aspen.
Half of the emission systems removed when the car came to me. I got a vacuum amp and hoses from a parts car for free. The problem was that the vacuum amp didn't work, just pulled EGR open at idle and engine kept stalling. Every other parts of the EGR-system work, I tested them.
I disassembed the amplifier and found out that the small rubber gasket/diagraph (the middle one in the picture) was broken and the manifold vacuum went straight to the EGR-line. I tried to glue the rubber thing, but I doupt it ever works again.
Are there gasket sets or new amplifiers avaliable?
PostPosted: Thu Jul 16, 2009 2:46 pm
No repair parts are available for the vacuum amplifier, and the amplifier itself is no longer available. Why not just remove the EGR system altogether? The car will run better.
PostPosted: Thu Jul 16, 2009 3:25 pm
Thanks Dan, that's what I expected.
I just try to keep the car as original as possible, it's a survivor. But EGR's got to go...
Inspection is not the problem, because pre-1978 cars don't have to run emission tests here.
PostPosted: Thu Jul 16, 2009 3:33 pm
I agree with Dan, remove the EGR from your slant. It'll run better, and you'll have less stuff under the hood.
'78 Volare 225
'67 Charger 318
PostPosted: Thu Jul 16, 2009 6:22 pm
If you are trying to keep the original look, hook all the EGR stuff back up, but put a plug (BB, etc) in the vacuum supply line. That will dissable the system, but keep the stock appearence.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 7 guests
