| disributor recurve https://slantsix.org/forum/viewtopic.php?t=36301 |
| Author: | 1980volare [ Wed Jul 15, 2009 8:00 pm ] |
| Post subject: | disributor recurve |
i recently came upon a extra dizzy out of a 76 duster, and im thinking of doing a recurve on it and droping it into my '80. just to play around with. right now my car likes alot of inital timing,and i have the vacuum advance out 3 turns. i have read many older posts, but im still confused about which springs will be good for me. in the 76 dizzy it has a light green spring and a thick heavy spring, and i belive its an 11r vacuum advance. any help would be greatly appricited.thanks |
| Author: | DusterIdiot [ Wed Jul 15, 2009 9:04 pm ] |
| Post subject: | Send me a PM.. |
Send me a PM... Pull the governor out and let me know if you have an 11R or a 9R dizzy... I will have a spring for you to install to replace the light spring, to get you started... -D.Idiot |
| Author: | HardCharger [ Thu Jul 16, 2009 12:50 am ] |
| Post subject: | Re: disributor recurve |
Quote: i recently came upon a extra dizzy out of a 76 duster, and im thinking of doing a recurve on it and droping it into my '80. just to play around with. right now my car likes alot of inital timing,and i have the vacuum advance out 3 turns. i have read many older posts, but im still confused about which springs will be good for me. in the 76 dizzy it has a light green spring and a thick heavy spring, and i belive its an 11r vacuum advance. any help would be greatly appricited.thanks
My slant liked a lot of initial too and I later found out it was because my timing chain was sloppy from all the miles.If you find a good retail source for the springs that are advised in previous recurve posts or from this thread, would you be so kind as to pass that info along in this thread? Thanks |
| Author: | bwhitejr [ Thu Jul 16, 2009 3:53 am ] |
| Post subject: | Distributor Recurve |
You can get springs from a member on this board by the name of bigslant6fan. bwhitejr |
| Author: | 66aCUDA [ Thu Jul 16, 2009 5:59 am ] |
| Post subject: | Re: Distributor Recurve |
Quote: You can get springs from a member on this board by the name of bigslant6fan.
Yup I have his spring pack, good stuff.bwhitejr Frank |
