It is currently Sun May 10, 2026 7:10 am
Phenolic or Metal Caliper Pistons?
Phenolic Caliper Piston 22%  22%  [ 2 ]
Metal Caliper Piston 78%  78%  [ 7 ]
Total votes: 9
PostPosted: Sun Jul 26, 2009 12:51 pm
Well Which is better and Why - Pros - Cons?
Thanks, Greg
PostPosted: Sun Jul 26, 2009 1:01 pm
I can't imagine the weight saving of plastic over metal in the piston caliper would be worth the added risk of failure. Maybe I am old fashioned and paranoid, but I like my brake parts to be as heavy duty and failure proof as possible.
PostPosted: Sun Jul 26, 2009 1:24 pm
Stainless right?
PostPosted: Sun Jul 26, 2009 3:25 pm
Phenolic caliper pistons are lighter and they're supposed to be less prone to corrosion problems. They also should transfer less heat to the piston.
When I looked into it a few years ago, there was a suggestion that the phenolic pistons were more likely to stick or chip. I went with metal.
Caliper Piston Discussion
 Post subject: What you can get...
PostPosted: Sun Jul 26, 2009 6:18 pm
The last time I went around on this a few years back, I had found that if you want to keep the metal piston, you will have to recondition your own calipers. Everybrand I could drum up for a set for rebuilt single piston calipers came with phenolics. I've been using a set of phenolics in the duster now for a few years and they work fine even under heavy duress with the aggressive brake pads I installed.
2 more cents...
PostPosted: Sun Jul 26, 2009 7:31 pm
When I was searching on roack auto you could get either stainless or Plastic.
You can get the pistons seperate from them too!
