| EGR vacuum amplifier repair/replace? https://slantsix.org/forum/viewtopic.php?t=36311 |
| Author: | 1967 Dart [ Thu Jul 16, 2009 12:30 pm ] |
Trying to fix the vacuum amplifier in 1976 Aspen. Half of the emission systems removed when the car came to me. I got a vacuum amp and hoses from a parts car for free. The problem was that the vacuum amp didn't work, just pulled EGR open at idle and engine kept stalling. Every other parts of the EGR-system work, I tested them. I disassembed the amplifier and found out that the small rubber gasket/diagraph (the middle one in the picture) was broken and the manifold vacuum went straight to the EGR-line. I tried to glue the rubber thing, but I doupt it ever works again. ![]() Are there gasket sets or new amplifiers avaliable? |
| Author: | SlantSixDan [ Thu Jul 16, 2009 2:46 pm ] |
No repair parts are available for the vacuum amplifier, and the amplifier itself is no longer available. Why not just remove the EGR system altogether? The car will run better. |
| Author: | 1967 Dart [ Thu Jul 16, 2009 3:25 pm ] |
Thanks Dan, that's what I expected. I just try to keep the car as original as possible, it's a survivor. But EGR's got to go... Inspection is not the problem, because pre-1978 cars don't have to run emission tests here. |
| Author: | Wesola78 [ Thu Jul 16, 2009 3:33 pm ] |
I agree with Dan, remove the EGR from your slant. It'll run better, and you'll have less stuff under the hood. |
| Author: | Charrlie_S [ Thu Jul 16, 2009 6:22 pm ] |
If you are trying to keep the original look, hook all the EGR stuff back up, but put a plug (BB, etc) in the vacuum supply line. That will dissable the system, but keep the stock appearence. |
