| You named the wire, now plug my hole! https://slantsix.org/forum/viewtopic.php?t=36329 |
| Author: | SimplyJeremy [ Fri Jul 17, 2009 10:15 pm ] |
| Post subject: | You named the wire, now plug my hole! |
So everyone has been so great, and I am near the end..... at least for now..... All back together, oil pressure sender wire attached, and started the car and the exhaust was leaking like a son of a gun.... or so I thought...... Went through checked all my gaskets and torque specs and couldn't figure out the problem til I put my hand behind the exhaust near the firewall and felt a very strong warm breeze..... from a big freakin hole that my old manifold did not have...... Guessing EGR? What would you recommend to close it up? Just a bolt and Lock washer? ![]() Thanks Again Jeremy And yes I am going to buy the books soon.... well once I find a job...... |
| Author: | Aggressive Ted [ Fri Jul 17, 2009 10:20 pm ] |
Yes, plug it with a brass plug if you can if not, use a stainless steel bolt and lock tight. |
| Author: | 65Dodge100 [ Sat Jul 18, 2009 4:20 am ] |
There are a lot of hole plugging ideas in THIS THREAD. Danny |
| Author: | GTS225 [ Sat Jul 18, 2009 5:01 am ] |
What the hell is THAT!? First time I've ever seen a threaded hole in that location. Is it supposed to be for an O2 sensor? I suggest you figure out the threads and get a proper plug for it. If the plug has to be steel, put some copper-based anti-sieze on it before threading it in......and do the same for those bolts holding the exhaust pipe flanges together. Roger |
| Author: | SimplyJeremy [ Sat Jul 18, 2009 6:24 am ] |
thanks all jeremy |
| Author: | SlantSixDan [ Sat Jul 18, 2009 7:01 am ] |
Yes, it's an O2 sensor port. |
| Author: | DusterIdiot [ Sat Jul 18, 2009 8:57 am ] |
| Post subject: | You could... |
Just put an O2 sensor in and wire it up to a gauge and see how your carb is doing (and use the data subjectively to dial in the mix and your timing a bit better...) -D.Idiot |
