It is currently Wed Nov 18, 2026 12:14 am
 Post subject: ebay exhaust manifolds
PostPosted: Tue Jul 21, 2009 12:50 pm
hello. i was wondering if anyone has used the 100 dollar exhaust manifolds on ebay. i assume they are probably crap. napa wants 400 bucks for a new dorman, cheapest i have found on the web for a dorman is about 250. no good used ones at the scrapyards around here, they are all cracked. thanks, andy.
PostPosted: Tue Jul 21, 2009 1:20 pm
Please see thread here and here.
 Post subject: re
PostPosted: Tue Jul 21, 2009 2:31 pm
thanks Dan. great stuff. will give the 100 dollar one a go. at least they are fresh material. most aftermarket stuff needs a little massaging to fit properly. also, i have decided to go with a rochester dual jet/offy 4bbl intake combo and will not be needing a 1 barrel. i have these on hand and i believe this carb is easily fitted with electric choke. thanks again, andy.
 Post subject: manifold
PostPosted: Fri Jul 24, 2009 7:44 pm
hello. ordered a exhaust manifold from 1A Auto. just under 100 bucks, free shipping. great communication and service so far. got here in a couple days. appears to be decent as far as mating flanges go. included triangle washers and shield for heat riser. a little rough where the casting lines are, will take a little cleaning with the die grinder to smooth out some sharp edges and a little wiggle room for getting socket on mounting nuts. time will tell. Andy.
