It is currently Tue Nov 17, 2026 4:48 pm
 Post subject: Gasket question
PostPosted: Mon Jul 13, 2009 9:36 am
Who makes a quality intake/exhaust gasket if you are using an aluminum intake and thick-flange headers? Contact info would be appreciated. Thanks.
SOLD! Went to New Zealand. '64 Valiant Signet 200, 2-dr hardtop. 225/4-speed/Pistol Grip, Offy 2-1bbl, Clifford headers.
Minimum government means maximum LIBERTY!
PostPosted: Mon Jul 13, 2009 10:43 am
It is very much worth your while to get the good gaskets for the manifolds-to-head and intake-to-exhaust junctions. The other good option is Rem-Flex.
PostPosted: Mon Jul 13, 2009 12:15 pm
I've been very happy with the REMFLEX gasket running aluminim intake and headers(both clifford pieces).
Ph# 1-866-641-7325 or REMFLEX dot com.
If you use the search function here you'll get a ton of info on both gasket companys.
 Post subject: Gasket ordered.
PostPosted: Tue Jul 14, 2009 9:07 am
Thanks, Dan. I ordered a pair from the aussie group. I appreciate the help.
 Post subject: Aussie gaskets arrived.
PostPosted: Sun Jul 26, 2009 9:42 am
and I got a pair ,delivered, for $38 due to the exchane rate. Remflex wanted over $50 for one! Hard to believe.
PostPosted: Sun Jul 26, 2009 11:32 am
Oh my :shock: Last one I ordered was thru local Napa and it was $34.Remflex must have gone up some,dang. Did you mention /6.org? they were being nice to us here,maybe not so much any more :(
