It is currently Sun May 10, 2026 8:07 am
 Post subject: Turbo 198
PostPosted: Thu Jul 23, 2009 6:03 pm
I have a spare T03 turbocharger from my front GLH turbo and have decided to use it on my '74 198/904 Duster. I want to keep it simple and am thinking about using a draw through carb. I going to talk to a local turbo rebuild shop about seeing what my turbo needs for it to be used in a draw through application and go from there. Any thoughts about what kind of carburetor to use? or about the turbo size that I am using for my 198? My goal is not to make a race car but a dependable and quicker daily street car. Since boost was limited to about 9psi on the early T1 non-intercooled 2.2turbo cars, I want to keep it right about there for this application. Any thoughts welcomed!...nico
PostPosted: Fri Jul 24, 2009 7:12 am
Talk to Gerry at G-Pop Shop on this forum. He is VERY knowledgable.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Jul 28, 2009 2:59 am
Thanks, I sure will!...
nico
PostPosted: Tue Jul 28, 2009 3:38 am
If that turbo is from an early Turbo I car it's already set up for draw through as the throttle body on early TI cars is ahead of the turbo. I'd use a 350 Holley with an external power valve reference so the power valve gets it's signal from manifold pressure, not under-carb pressure.
PostPosted: Wed Jul 29, 2009 2:56 am
Yup, and the early T1 cars were also port fuel injected and the t-body and turbo were only managing air....I want to be sure it (the turbocharger) can handle fuel as well as air on this 198 project...thanks, nico
PostPosted: Wed Jul 29, 2009 4:15 am
The fuel shouldn't hurt anything. You've already got a face seal to handle vacuum rather than a dynamic seal. The fuel and oil will each stay where they belong.
