It is currently Tue Nov 17, 2026 12:26 am
 Post subject: Dumb question.......
PostPosted: Fri Jul 31, 2009 9:33 am
Car Model: '23 T-bucket
Senior moment.......Can I run a slant on an engine test stand, without the flywheel or flex plate/converter?
Can't remember offhand if it's internally or externally balanced engine.
Roger
PostPosted: Fri Jul 31, 2009 10:11 am
You'd have one heck of a time starting it wouldn't ya?
Chris'
Autobody
Restoration
Service
PostPosted: Fri Jul 31, 2009 10:36 am
Break out the Old hand crank Model t Style!
PostPosted: Fri Jul 31, 2009 3:23 pm
DOH!! Another senior moment! :oops:
(Maybe I could rig up a recoil from a B&S 5hp motor. :wink: )
Roger
PostPosted: Fri Jul 31, 2009 6:06 pm
It would be fairly easy to use an old bellhousing or auto trans case for the rear mount on the stand. Then you'd have a place for the starter too.
PostPosted: Fri Jul 31, 2009 8:14 pm
Aarrrgggggg!!! :x I found my flywheel and cleaned it up a bit, got some grade 8 bolts, and discovered that the pilot is smaller than the crank flange's pilot. Damn.....it's an early flywheel, and won't fit on a later crank. Guess I'm going to have to have it hogged out...........Monday. :(
Roger
PostPosted: Fri Jul 31, 2009 8:59 pm
Are you sure SAE Grade 8 is correct? In most every application I've worked on, Grade L9 screws are required. Use blue Loctite when installing them.
Hmmm...an excuse to add a lathe to your tool collection? (I have 3)
Ken
PostPosted: Sat Aug 01, 2009 5:04 am
Well, I can't be sure 8's are correct, but this is a short-term run on a test stand. As for the lathe....yes, I'd very much like to have one, just don't have enough room to put one in place.
Roger
Users browsing this forum: Ahrefs [Bot], Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 5 guests
