It is currently Tue Nov 17, 2026 12:48 am
 Post subject: starter replacement
PostPosted: Wed Jul 29, 2009 5:13 am
i have a starter that came off a 95 Dakota or something like that on my 77 Volare. anybody know what the swtichout vehicles are for these smaller starters? also can the solenoid be replaced or repaired without replacing the starter?
David at the Beach in NC
PostPosted: Wed Jul 29, 2009 5:37 am
I ordered a 93 V6 starter for my 72 Duster. You should be fine.
PostPosted: Wed Jul 29, 2009 2:02 pm
I'm running a starter off a 93 Dakota V6. No worries.
PostPosted: Wed Jul 29, 2009 3:46 pm
I also installed a starter from a '93 Dakota V6 on my '78 Volare 225. Works fine.
'78 Volare 225
'67 Charger 318
PostPosted: Wed Jul 29, 2009 6:22 pm
I'm surprized more slanters didn't know about this. Was talking to ArmyofChuckness today and he knows it now! I though the one on my Duster was bad so I bought another one. Turned out I had a dead battery :roll: Didn't have a volt meter at the time :roll:
So the spare one is going on the FartDart.
PostPosted: Thu Jul 30, 2009 9:10 am
thanx for the input.
 Post subject: Re: starter replacement
PostPosted: Thu Jul 30, 2009 8:24 pm
The "lightweight" starters, made by Nipondenso, were used on late 80's and newer vehicles domestic Mopars. All the trucks and vans have them. There are two different starters, one for 6 cylinder and one for 8 cylinder. Putting them side by side you'll notice the motor is slightly longer on the 8 cylinder version. Remove the 3 Phillips screws to expose the solenoid contacts.
The weak point in these starters is the solenoid contacts. They can be replaced, as can the plunger. iirc someone on the MML www.moparmailinglist.com posted some mail order sources a couple of years ago, but I lost them in a computer crash. Try posting a request there. You can also try your local starter/alternator/generator rebuilding shops. The contacts and plunger shouldn't cost more than ~$15-20. There are also an insulating sleeve&cap on the motor/solenoid cable and a drain tube in the motor housing. These often deteriorate and should be replaced if they're in poor condition. Be careful with solvents when cleaning the starter. These elastomeric components will swell and fall apart if you get any solvent on them.
If you disassemble the starter, the ball bearings are standard industrial sizes, available from www.mscdirect.com and other industrial suppliers. Use shielded bearings except for the one that's exposed to the outside, by the drive clutch, which should have rubber seals. The originals are all shielded style iirc. The brushes and commutator seem to last forever. There's a snap ring on the drive clutch iirc that is a pita to remove.
Try to use a copper nut for the battery cable terminal. Using steel nuts on the copper posts will cause galvanic corrosion of the nuts, making them difficult to remove without snapping the terminal. At the junkyard just cut the wires and worry about removing the nuts when you have it on your workbench and have the proper tools available.
Ken
PostPosted: Fri Jul 31, 2009 8:32 am
This might help.
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
