| Dumb question....... https://slantsix.org/forum/viewtopic.php?t=36541 |
| Author: | GTS225 [ Fri Jul 31, 2009 9:33 am ] |
| Post subject: | Dumb question....... |
Senior moment.......Can I run a slant on an engine test stand, without the flywheel or flex plate/converter? Can't remember offhand if it's internally or externally balanced engine. Roger |
| Author: | CARS [ Fri Jul 31, 2009 10:11 am ] |
You'd have one heck of a time starting it wouldn't ya? |
| Author: | Greg Ondayko [ Fri Jul 31, 2009 10:36 am ] |
Quote: You'd have one heck of a time starting it wouldn't ya?
Break out the Old hand crank Model t Style!Greg |
| Author: | GTS225 [ Fri Jul 31, 2009 3:23 pm ] |
******************************************************DOH!! Another senior moment! (Maybe I could rig up a recoil from a B&S 5hp motor. Roger |
| Author: | slantzilla [ Fri Jul 31, 2009 6:06 pm ] |
It would be fairly easy to use an old bellhousing or auto trans case for the rear mount on the stand. Then you'd have a place for the starter too. |
| Author: | GTS225 [ Fri Jul 31, 2009 8:14 pm ] |
Aarrrgggggg!!! Roger |
| Author: | RustyRamcharger [ Fri Jul 31, 2009 8:59 pm ] |
Quote: Aarrrgggggg!!!
Are you sure SAE Grade 8 is correct? In most every application I've worked on, Grade L9 screws are required. Use blue Loctite when installing them.Hmmm...an excuse to add a lathe to your tool collection? (I have 3) Ken |
| Author: | GTS225 [ Sat Aug 01, 2009 5:04 am ] |
Well, I can't be sure 8's are correct, but this is a short-term run on a test stand. As for the lathe....yes, I'd very much like to have one, just don't have enough room to put one in place. Roger |
