| V/SA Questions https://slantsix.org/forum/viewtopic.php?t=36552 |
| Author: | Myron Fountain [ Fri Jul 31, 2009 9:13 pm ] |
| Post subject: | V/SA Questions |
[ 1] Are V sixs allowed to run with the inlines? [ 2] What are some slant six combos that would be competive?[ 3] Who should I talk to about a camshaft?[ 4] The record holder is a 81 Pontiac does anyone no what model and engine type it is? [5 ] What would be the shortest wheelbase Mopar with a super six that could make the weight break? Thanks |
| Author: | slantzilla [ Sat Aug 01, 2009 3:51 am ] |
| Post subject: | Re: V/SA Questions |
Quote: [ 1] Are V sixs allowed to run with the inlines? [ 2] What are some slant six combos that would be competive?[ 3] Who should I talk to about a camshaft?[ 4] The record holder is a 81 Pontiac does anyone no what model and engine type it is? [5 ] What would be the shortest wheelbase Mopar with a super six that could make the weight break? Thanks
1. Yes2. 2 barrel/solid lifter motors-F/M bodies 3. Tim Cole at Comp Cams-Most stock racers won't talk about their cam 4. Probably a 3.8 V-6 5. Volare/Aspen Mike Jeffrey has a 2 door '80 Diplomat and has been faster than the national record already. Boardmember pmarvets runs an Aspen wagon and is fast enough to win class. You have to run at least .5 under index to win class even if you're the only car. |
