| dakota manual https://slantsix.org/forum/viewtopic.php?t=36623 |
| Author: | bigdaisy19k [ Thu Aug 06, 2009 7:22 pm ] |
| Post subject: | dakota manual |
found a good deal on a mid 90s 2wd manual dakota trans and rear.....will and how can i put this behind my six?...........sorry about the typing problems...im using my phone haha |
| Author: | Joshie225 [ Thu Aug 06, 2009 7:30 pm ] |
Do you really want a 4:1-ish 1st gear and wheels that stick out about 8" per side? |
| Author: | volaredon [ Thu Aug 06, 2009 9:40 pm ] |
Quote: Do you really want a 4:1-ish 1st gear and wheels that stick out about 8" per side?
a Dakota rear won't stick out that bad; the bigger pitfall is if it is newer than 90, it will have 6 lug axles.
| Author: | bigdaisy19k [ Thu Aug 06, 2009 10:30 pm ] |
Quote: Quote: Do you really want a 4:1-ish 1st gear and wheels that stick out about 8" per side?
a Dakota rear won't stick out that bad; the bigger pitfall is if it is newer than 90, it will have 6 lug axles. |
| Author: | bigdaisy19k [ Fri Aug 07, 2009 10:11 am ] |
no mre late night replies for me....i forget what im typing....anybody sell adaptors? |
| Author: | Joshie225 [ Sat Aug 08, 2009 3:29 am ] |
No, but you can put the 5-lug Dakota axles in the '96 and older 6-lug housing. |
| Author: | bigdaisy19k [ Mon Aug 10, 2009 11:32 pm ] |
ok...talked to lot-o-shops...nobody knows if u can regear it...oh well...theres always an auto....maybe ill still get it and put it in my truck..thanks for all the answers still gonna get the rear though...cant pass up bettier gearing although i might have a shure grip....i dunno....im getting more on the plate everyday.... now where did i put my lotto ticket? |
| Author: | cavisco [ Mon Aug 17, 2009 8:07 pm ] |
Forum member sixinthehead has done this swap. http://www.slantsix.org/forum/viewtopic.php?t=10197 |
| Author: | ply/six [ Tue Aug 25, 2009 10:41 am ] |
| Post subject: | trans and diff swap |
I just completed a simular swap into a Plymouth Caravelle (1978) This is the same platform as the aspen. I put an 89 dakota sport 3:91 posi,1975 3peed OD( heavy case) behind my slant. Works well after I corrected the pinion angle. I still have a vibration when I push in the clutch. I'm pretty sure it's the clutch brg. Good luck. |
