| what size is this bolt? https://slantsix.org/forum/viewtopic.php?t=3663 |
| Author: | Rebecca [ Wed May 22, 2002 12:20 pm ] |
| Post subject: | what size is this bolt? |
The bolt that goes from the alternator bracket into the head on my '63 Valiant seems to have disappeared. The car is making a terrible squeak, does anyone know what size this bolt is so I can get a replacement? Thanks! rebeccanovak@yahoo.com |
| Author: | Doc. [ Wed May 22, 2002 12:52 pm ] |
| Post subject: | Re: what size is this bolt? |
: The bolt that goes from the alternator bracket : into the head on my '63 Valiant seems to : have disappeared. The car is making a : terrible squeak, does anyone know what size : this bolt is so I can get a replacement? : Thanks! 3/8 - 16 unc, 9/16 wrench hex head, about 1/2 to 5/8 long (threaded section) DD |
| Author: | CrAlt [ Thu May 23, 2002 9:44 am ] |
| Post subject: | Hey Boltman, Crank bolt size? |
What size is the Crank bolt? Would be nice to have that pull the ballencer back on rather then use a hammer again... Thanks! PS: The mopar bushing kit is 22bux...But my local speed shop has Chevy ones that a few bux...I hear they are the same. Quote:
: : 3/8 - 16 unc, 9/16 wrench hex head, about 1/2 : to 5/8 long (threaded section) : DD cralt@optonline.net |
| Author: | rebecca [ Fri May 24, 2002 9:50 am ] |
| Post subject: | Re: Hey Boltman, Crank bolt size? |
Thanks for the information, nothing quite like the relief of fixing a hideous noise in the car for 32 cents rebeccanovak@yahoo.com |
| Author: | Dart270 [ Fri May 24, 2002 10:27 am ] |
: What size is the Crank bolt? Would be nice to : have that pull the ballencer back on rather : then use a hammer again... : : Thanks! : PS: The mopar bushing kit is 22bux...But my : local speed shop has Chevy ones that a few : bux...I hear they are the same. CrAlt, The crank bolt is 3/4 fine thread X 1.5" long. You will likely need a longer one (2" or more)than that to install a balancer though. You gonna make any Slant races this year? Cheers, Lou |
| Author: | Doctor Dodge (Doug Dutra) [ Fri May 24, 2002 7:49 pm ] |
: What size is the Crank bolt? Would be nice to : have that pull the balancer back on rather : then use a hammer again... I use a 5" long piece of 3/4 - 16 unf threaded stock and a large nut / washer. With this I can thread-in the stud under no load then wrench down the nut to push-on the damper. (this keeps you from wearing-out the crank snout threads)I use the washer in between the nut & damper face and coat it with anti-seize to cut down on the friction. : : PS: The mopar bushing kit is 22bux...But my : local speed shop has Chevy ones that a few : bux...I hear they are the same. These work but they are a little longer so I cut them in half (lathe work) so I get a "2 bushings for 1" deal! DD |
