| Aluminum Master Cylinder Ports question https://slantsix.org/forum/viewtopic.php?t=36642 |
| Author: | Thropar [ Sat Aug 08, 2009 8:13 am ] |
| Post subject: | Aluminum Master Cylinder Ports question |
I'm converting to a late model aluminum master cylinder (82 truck 1 1/8" bore) and I don't know which port feeds F/R. I know only one port has the residual valve for the rear drums... I don't want to cross it up.... anyone know the skinny? There are 2 port sizes: front-9/16" ... rear-1/2"... thanks |
| Author: | 6shotvanner [ Sat Aug 08, 2009 8:46 am ] |
Don't know if this will help any but the m/c on my 83 van is front to rear an rear to front.They're plumbed into a pv/block before going hither an yon so rear port goes to front of pv/block then to front brakes etc. |
| Author: | Thropar [ Sat Aug 08, 2009 10:28 am ] |
Thanks, I think most of the Chrysler products are like this but I'm not sure. (Rear reservoir feeds the front). |
| Author: | Charrlie_S [ Sat Aug 08, 2009 5:40 pm ] |
Be carefull, on the fitting for the front port. It is 9/16, but a 20 pitch thread. Just about any fitting you find in a parts store will be 9/16- 18 thread. It won't work. Will strip the threads after it goes in about 1/2 way. |
| Author: | Thropar [ Sat Aug 08, 2009 7:02 pm ] |
Thanks Charlie, I noticed that. Where do you source those fittings? |
| Author: | 65Dodge100 [ Sat Aug 08, 2009 10:42 pm ] |
Quote: Where do you source those fittings?
Here is one place:http://store.fedhillusa.com/a163.aspx A parts store may have one or can order it though. Danny |
| Author: | Charrlie_S [ Sun Aug 09, 2009 5:25 am ] |
| Author: | Thropar [ Sun Aug 09, 2009 7:25 am ] |
Thanks a bunch guys, I appreciate the info very much. |
| Author: | Dart270 [ Sun Aug 09, 2009 3:30 pm ] |
Every Chrysler MC I've seen has front port to rear brakes and... Lou |
