| 75 a body disks on a 65 b body mopar https://slantsix.org/forum/viewtopic.php?t=36691 |
| Author: | 75customdart [ Tue Aug 11, 2009 11:59 am ] |
| Post subject: | 75 a body disks on a 65 b body mopar |
is this swap possible? if so what parts are needed? thanks for the help |
| Author: | 65 dartman [ Tue Aug 11, 2009 12:22 pm ] |
Reuse your UCA. You'll need the 73-76 steering knuckle and if available the dust shield. I'd go with new rotors, bearings, calipers and hoses - all readily available new. I did the swap on a 69 Charger and 65 Coronet 440 and works like a charm. |
| Author: | 75customdart [ Tue Aug 11, 2009 1:21 pm ] |
thanks for the help. i am also doing this swap on a 65 coronet 440. post so pictures when done |
| Author: | andyf [ Wed Aug 12, 2009 8:43 pm ] |
The late model A body stuff will bolt right onto an early B body car. You can run the caliper in front of the knuckle (recommended) or to the rear. If you have an aftermarket anti-sway bar you might need to spend some time to get everything to play together. I wrote a magazine article on this exact swap years ago. Do a Google search on my name and you'll find it. Andy Finkbeiner |
