| Oil "pipe" came off during oil change https://slantsix.org/forum/viewtopic.php?t=36716 |
| Author: | Wesola78 [ Wed Aug 12, 2009 6:24 pm ] |
| Post subject: | Oil "pipe" came off during oil change |
Okay, this is the "pipe" thing (sorry, I don't know the technical term) that the oil filter screws on to. Whet I removed the oil filter to change it two days ago, this pipe came off screwed into the oil filter, instead of the oil filter unscrewing from it. I just removed it from the filter and reattached it to where it would normally be. Is there some sort of gasket on or near the threads of this thing? I have noticed a slight oil leak coming from the general area of this, which is close to/part of the oil pump. Suggestions? I don't need a new oil pump do I? Thanks for any advice! Oh yeah, this is the 225 in my '78 Volare 2-door coupe. |
| Author: | DusterIdiot [ Wed Aug 12, 2009 6:42 pm ] |
| Post subject: | It happens... |
THe 'standpipe' (tall if it has the back flow flap), and short if it's just the 'threads' the filter threads onto... Just screw it back in and tighten it up a bit, and replace your oil filter...done. -D.Idiot |
| Author: | Wesola78 [ Wed Aug 12, 2009 6:50 pm ] |
Thanks Rob! |
| Author: | 1969ronnie [ Wed Aug 12, 2009 10:37 pm ] |
yes ,just thread it back in and one small o ring between the adapter and oil pump block . ron |
