It is currently Sun Nov 15, 2026 11:47 pm
PostPosted: Wed Aug 12, 2009 6:24 pm
Okay, this is the "pipe" thing (sorry, I don't know the technical term) that the oil filter screws on to. Whet I removed the oil filter to change it two days ago, this pipe came off screwed into the oil filter, instead of the oil filter unscrewing from it. I just removed it from the filter and reattached it to where it would normally be.
Is there some sort of gasket on or near the threads of this thing? I have noticed a slight oil leak coming from the general area of this, which is close to/part of the oil pump.
Suggestions? I don't need a new oil pump do I? :shock:
Thanks for any advice! :)
Oh yeah, this is the 225 in my '78 Volare 2-door coupe.
'78 Volare 225
'67 Charger 318
 Post subject: It happens...
PostPosted: Wed Aug 12, 2009 6:42 pm
THe 'standpipe' (tall if it has the back flow flap), and short if it's just the 'threads' the filter threads onto... Just screw it back in and tighten it up a bit, and replace your oil filter...done.
PostPosted: Wed Aug 12, 2009 6:50 pm
Thanks Rob! :D
'78 Volare 225
'67 Charger 318
PostPosted: Wed Aug 12, 2009 10:37 pm
yes ,just thread it back in and one small o ring between the adapter and oil pump block . ron
