| Identify a hydro cam? https://slantsix.org/forum/viewtopic.php?t=36738 |
| Author: | Rick Covalt [ Fri Aug 14, 2009 9:20 am ] |
| Post subject: | Identify a hydro cam? |
Is there an easy way to tell if you have a hydro cam or mechanical cam? I have a Lunati cam I bought at Carlisle about 10 years ago. It was new but had no card with it. I figured I could look up the numbers and tell what it was. Long and short is the only way they could tell me what I have was to send it back and I never did. Fast forward. I want to put this cam in a hydro motor and swap over to mechanical valve gear but I don't know what it is for? The valve lift is only about .400 so it is small but it is new and I have it, so I was going to use it. The only thing that looks a bit odd to me is that the exhaust lobe appears to be open quite a bit longer than another cam I have on hand. The exhaust lobe is almost flat at full open. I'm sure one of you experts can help me. Rick |
| Author: | Doc [ Fri Aug 14, 2009 10:52 am ] |
Is there a manufacturer's name or any numbers on the "butt ends" of the cam? (they likely used someone else to grind theis cam) You already know the answer... send it to a cam grinder and have them run a profile sheet on that cam. DD |
| Author: | Rick Covalt [ Fri Aug 14, 2009 1:06 pm ] |
| Post subject: | I Know |
I know that I know, you Know! Anyway I didn't know if there was a easy identifier or not. Sounds like or not. Rick |
| Author: | Doc [ Fri Aug 14, 2009 2:02 pm ] |
You can install it and use a degree wheel & a dial indicator to plot what it is... but you will spend a few hours doing that work. DD |
