| Holley 1920 stalls at a complete stop. https://slantsix.org/forum/viewtopic.php?t=36748 |
| Author: | zerglin87 [ Sat Aug 15, 2009 1:05 pm ] |
| Post subject: | Holley 1920 stalls at a complete stop. |
I been working my butt off trying to get the darn holley 1920 carb running and soo far i got it running, albiet a higher idle, the only issue is that whenever i slow down to a complete stop it will diesel and stall on me immediately unless i have my foot on the throttle a little bit. I really want to get this fixed before college starts. |
| Author: | 65Dodge100 [ Sat Aug 15, 2009 1:47 pm ] |
In THIS THREAD you said: Quote: ...so i decided to do a partial rebuild and clean everything that i could take apart inside the guts. Can you tell us what a partial rebuild includes? Did you get new gaskets? Quote: That made it run better but now we had an issue of a certain vaccuum forcing the car to stall, if i plug the vaccuum it will not stall at all and drive normally, Do you mean a vacuum hose? What does it go to or where is the leak? A vacuum leak could easily cause your problem. Danny |
| Author: | zerglin87 [ Sat Aug 15, 2009 7:52 pm ] |
Its a vacuum for the economizer, whenever it lifts the economizer the car will immediately diesel and stall, my neighbor suggested that i close out the economizer vacuum hole so it wont engage/disengage the economizer, we made a gasket that covers the vaccuum passage in the carb but he wants me to get a thicker one, if i keep the economizer pressed against the power valve lever it runs fine. |
| Author: | Aggressive Ted [ Sat Aug 15, 2009 10:54 pm ] |
Your carb is plugged up with something. Take the Economizer body off and clean it very carefully with spray. You may have to soak it in carb cleaner. |
| Author: | novadude [ Mon Aug 17, 2009 1:50 pm ] |
| Post subject: | Re: Holley 1920 stalls at a complete stop |
Would I be out of line to offer you a rebuilt 1920 for 50$ ?? Ran great on the Slant 6 in a 71 dart, I live in zip 93610, you can PM me if interested. |
| Author: | zerglin87 [ Fri Aug 21, 2009 3:28 am ] |
Ehh I tried cleaning the economizer twice as of today, still stalls, I think its running rich, ill adjust it soon. |
| Author: | Aggressive Ted [ Fri Aug 21, 2009 7:39 am ] |
What size jet are you running? |
