| dual, single barrel, Carter manifold? https://slantsix.org/forum/viewtopic.php?t=36802 |
| Author: | Rod Rocket [ Thu Aug 20, 2009 11:25 pm ] |
| Post subject: | dual, single barrel, Carter manifold? |
does anyone still make a dual, single barrel, Carter manifold? If not does someone have one they want to get rid of? |
| Author: | wvenable [ Fri Aug 21, 2009 4:54 am ] |
If you are talking about the Offy, they are still around. Check e-bay, log onto the parts wanted section and check the section of this board that tells of slant six "friendly" venders. Welcome! |
| Author: | kesteb [ Fri Aug 21, 2009 10:43 pm ] |
Offenhauser still makes the dual 1v manifold, so don't pay ridiculous ebay prices for one. Do a search for an Offy retailer and buy a new one from them. |
| Author: | wvenable [ Sat Aug 22, 2009 4:32 am ] |
RR, to better answer your question, you are looking for the Offy manifold part # 5041. Do a web search for Exeter Auto Supply. Slant stuff can be found on page 25 of their PDF catalogue. Dan Marvin is the owner and he lists the manifold at $293.99. Several of us have dealt with him before and have gotten very good prices and excellent service. Tell him you are a member of this forum and ask him for his car club discount. This should get you a 5% savings. Also be aware that quality control at Offy may be slipping. In our valve cover group buy the polishing could have been better. Continue to search this site for this set up. Many guys modify this manifold for a dual 2bbl set up. Hope this helps, Wayne. |
| Author: | tmj91 [ Sat Aug 22, 2009 1:48 pm ] |
how about this... parts123 aaamarine |
| Author: | wvenable [ Sat Aug 22, 2009 2:40 pm ] |
tmj91, aaamarine was a vendor that we considered using with the Offy valve cover group buy. There were commuication problems so EAS won. I am sure that Dan can do better. Thank you for the research. |
