| Hole inside intake https://slantsix.org/forum/viewtopic.php?t=36812 |
| Author: | 6shotvanner [ Fri Aug 21, 2009 8:43 pm ] |
| Post subject: | Hole inside intake |
I'm suffering from search function overload so if this is an old question sorry Ok inside my supersix intake is the hole(under carb area) where exhaust gas from EGR was introduced back to the intake.So the thing that's bugging me is what do we do with this hole? With EGR removed/blocked off it leaves a fairly big cavity to collect gas under floor of intake with nothing to push it out.I suppose that the suction of intake might draw anything out of said hole/cavity but just not sure.So am I just over thinking this?,not a big problem? There's no threads in it so threading cast intake for a plug just doesn't set right with me,I have visions of the intake craaaacckkkking |
| Author: | emsvitil [ Fri Aug 21, 2009 11:20 pm ] |
The gas will evaporate out............ |
| Author: | 73NorthernDuster [ Sat Aug 22, 2009 6:03 am ] |
| Post subject: | I put a plug in mine |
If it is an iron intake like mine threading for a plug was not a big deal. If it is an aluminum 2bbl then I am not sure. I got the idea of a plug from another post here a while back and my old school mechanic didn't seem to think it would hurt the manifold. I just ran a coarse thread tap through a few times and put in a pipe plug. There seemed to be lots of meat there so its shouldn't crack. cheers Brent |
| Author: | Rug_Trucker [ Sat Aug 22, 2009 8:42 pm ] |
JBWeld it and "faggittaboutit." |
| Author: | Wesola78 [ Sun Aug 23, 2009 7:48 am ] |
I'm with Rugtrucker. |
| Author: | Aggressive Ted [ Sun Aug 23, 2009 8:52 am ] |
I JB Welded mine about 3 years ago. Still looks good today! I made it into a small mountain with a rounded top. |
| Author: | 6shotvanner [ Sun Aug 23, 2009 10:34 am ] |
JB Weld it is then |
| Author: | madmax/6 [ Sun Aug 23, 2009 12:27 pm ] |
Not needed,waste of time,,,,but thats what I would do,Mark |
| Author: | 6shotvanner [ Sun Aug 23, 2009 12:52 pm ] |
And me too,I figure it's like "Chicken soup for the motor",it couldn't hoit |
| Author: | Rug_Trucker [ Sun Aug 23, 2009 12:59 pm ] |
Quote: I JB Welded mine about 3 years ago. Still looks good today!
Ever seen a "turtle" for the single plane intakes? JBTurtle!
| Author: | Aggressive Ted [ Sun Aug 23, 2009 7:55 pm ] |
Yes! as a matter of fact I have! My single barrel intake is all aluminum. It seems to stick just fine and the gas does not soften it. I think the little JB Weld mountain/turtle helps to disperse the gas vapors. |
| Author: | Rug_Trucker [ Mon Aug 24, 2009 4:56 am ] |
If only they made a "Turbinator" for the super six! |
