| What to Up-grade first... https://slantsix.org/forum/viewtopic.php?t=3687 |
| Author: | Brent [ Mon May 27, 2002 10:54 pm ] |
| Post subject: | What to Up-grade first... |
I have around 1,500 to spend on my slant that is in my 1965 barracuda it is bone stock right now what mods would you all suggest that i could to to increase performance, and reliability for 1,500? Starbravo@aol.com |
| Author: | Gene [ Tue May 28, 2002 9:15 am ] |
| Post subject: | Re: what to expect |
Brent, if the motor in your car is the original, I would rebuild it that way. If you want to increase performance, there are two thing's you can do without messing with the motor itself, they are:Intake & Exhaust; The two most common approaches are putting on a "super six" induction system, and, expanding the exhaust system with a header setup from "I can't think of the name of the company!, but they make a header system for slant six's; Or, using a "Dutra" setup, which my car has, and, it has worked fine. Anyway, taking this approach will significantly increase performance while maintaining the integrity of your motor. Gene h.ahart@worldnet.att.net |
| Author: | Doc. [ Tue May 28, 2002 1:12 pm ] |
| Post subject: | Re: What up-grades to do first . . |
: i have around 1,500 to spend on my slant that : is in my 1965 barracuda it is bone stock : right now what mods would u all suggest that : i could to to increase performance, and : reliability for 1,500? This may sound funny but for me, anti sway bars along with good shocks & tires are the first things I like to do to a SL6 A-Body, make it handle so you don't have to slow down for the corners! DD |
| Author: | GTS225 [ Wed May 29, 2002 11:12 am ] |
: This may sound funny but for me, anti sway bars : along with good shocks & tires are the first : things I like to do to a SL6 A-Body, make it : handle so you don't have to slow down for the corners! ************************************************** Hmmmmm, Doug's got a very valid point.....power is NOTHING, without control. If you can't tell it when to go, where to go, and when to stop, 5000hp isn't very useful to anyone. Roger GTS225@aol.com |
| Author: | Brent [ Wed May 29, 2002 10:10 pm ] |
where would be the best place to get sway bars as my cuda is not an ss i don't think it even has brakets for them. I have some shocks coming right now and have thought about Magnumforce's coil over conversion has anyone used or heard about these? I am soon to be converting to discs as soon as i get the rotors calipers, and master cylinder cleaned up. I was just wondering how much modifiying the six on its own would be to get an idea of when to take the hammer to my piggy bank. Starbravo@aol.com |
| Author: | Matt Cramer [ Thu May 30, 2002 7:54 am ] |
: where would be the best place to get sway bars : as my cuda is not an ss i don't think it : even has brakets for them. That's no problem, as Addco and other aftermarket sway bars don't mount in the stock location anyway. The Addco front bar I have attaches to holes I drilled in the K-member and to brackets that bolt onto the shock mounts. Sway bars are probably the most worthwhile suspension upgrade you can put on an A-body. The bars are availible from J.C. Whitney, Morgan Performance, Summit, and others. : : I have some shocks coming right now and have : thought about Magnumforce's coil over : conversion has anyone used or heard about : these? I'm not sure coilovers are worthwhile. You can already adjust the ride height anyway, and I don't think this kit does anything to change the suspension geometry. If you must get expensive parts, the Magnum Force tubular upper control arms are probably a better buy - or perhaps a set of fully adjustable Konis. |
| Author: | Gene [ Thu May 30, 2002 2:14 pm ] |
: Brent, the name of the compnay that makes the header setup I couldn't remember the other day is "Clifford". : h.ahart@worldnet.att.net |
