| Ideal /6 parts https://slantsix.org/forum/viewtopic.php?t=36932 |
| Author: | Speeddm [ Mon Aug 31, 2009 2:22 pm ] |
| Post subject: | Ideal /6 parts |
Hi there everyone. Question for you all. If you were to build the perfect longblock what would it consist of ie; Head casting # Block casting # This is going to be a Nitrous motor and is going to see LOTS of abuse. Your thoughts are welcome. Thansk |
| Author: | Doc [ Mon Aug 31, 2009 2:47 pm ] |
See these threads: DD http://www.slantsix.org/forum/viewtopic ... ight=twins http://www.slantsix.org/forum/viewtopic ... ight=twins http://www.slantsix.org/forum/viewtopic ... ight=twins |
| Author: | Speeddm [ Wed Sep 02, 2009 7:10 am ] |
Ok great thanks Doug. Engine building tricks are very useful. and your info confermed what I ve found with the BH blocks. But what about heads Ive got o 30+ to choose from. OR others opinions from other people. |
| Author: | Aggressive Ted [ Wed Sep 02, 2009 11:27 am ] |
Other opinions... I like the 74 on up blocks and the 78 on up heads. The 78 and up heads have the newer chamber and use the peanut plugs. The engine stays much cleaner too. |
