It is currently Fri Apr 24, 2026 12:18 pm
 Post subject: Buzzing speedometer
PostPosted: Sun Oct 04, 2009 11:14 am
What causes a speedometer to make a buzzing noise as you drive? THe buzzing increases with speed, so I assume it is tied to the rotation of the speedometer cable and the gears inside the speedometer. Can I take it apart and lube something or tighten something up to make it go away?
This is on a 83 Dodge van.
PostPosted: Sun Oct 04, 2009 1:06 pm
Try lubricating the cable. Also inspect the cable housing for kinks and dents where the inner cable might be binding.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Oct 04, 2009 1:11 pm
Thanks! I will get a tube of graphite and lube the cable.
PostPosted: Sun Oct 04, 2009 5:23 pm
Vaseline will work too.
What you have is the infamous "Chrysler buzz". :D
PostPosted: Sun Oct 04, 2009 5:34 pm
Thanks big D. I'll give the Vaseline a try too.
