It is currently Sat Oct 24, 2026 3:56 am
 Post subject: slant six swap.
PostPosted: Sat Jun 01, 2002 6:03 pm
Hello. I have some questions regarding swapping a slant six. I have a 1975 Dart with lots of miles on it and the original slant six is tired. I also own a 1969 Valiant 100 with 58,000 miles on it and is going throuugh a small block swap. The six in the Valiant says super six on the air cleaner ( IT IS A 1 BBL. ). I have been doing some homework on the 225 and figure the 69 motor to be at about 110 hp. I also understand that the slant went through a tail spin in hp going from the 110 range to the 80 hp range between 73 and 76 if I did the math right? i figure the 110 hp motor with the addition of a 2 bbl super six setup and a set of splitfire plugs and wires should give me about 45 more hp than the 75 motor had and should make my Dart fly. The questions are besides the different K frame is there any other surprises in store on this swap and how can I tell if this is a 225 motor and not a 170? Is there any marks on the motor to tell me the size?
miehle@msn.com
 Post subject: Re: slant six ID.
PostPosted: Sun Jun 02, 2002 7:59 am
: besides the different K frame is there any
: other surprises in store on this swap and
: how can I tell if this is a 225 motor and
: not a 170? Is there any marks on the motor
: to tell me the size?
The ID numbers are stamped on the engine block and cast into the side of the engine block.
Go to this article for more info.
<A HREF="http://www.slantsix.org/articles/sa-franks-book/pg2.jpg">http://www.slantsix.org/articles/sa-franks-book/pg2.jpg</A>
PostPosted: Mon Jun 03, 2002 1:40 pm
For engine size, also check the length of the short water pump hose. A 225 or 198 has a 3" hose, the 170 has a 2" hose.
Chuck
: The ID numbers are stamped on the engine block
: and cast into the side of the engine block.
: Go to this article for more info.
: DD
: <A HREF="http://www.slantsix.org/articles/sa-fra ... pg2.jpg</A>
webmaster@omnipages.com
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 12 guests
