| What's that ratio?? https://slantsix.org/forum/viewtopic.php?t=3698 |
| Author: | Trysix [ Thu May 30, 2002 6:30 pm ] |
| Post subject: | What's that ratio?? |
I have a 65 Coronet /6 of course...just in case you guys have forgotten.I'm pretty irregular on the internet action. Anyway I don't want to tear my 8 3/4 rear down...so I have spun the the tires and driveshaft and counted revolution until I'm blue. I keep comming up with 3.33 gear ratio. I've been told they didn't make a 3.33. Does anyone know what ratios were offered in 1965 B bodies? Thanks Trysix Soupitup@msn.com |
| Author: | Doctor Dodge (Doug Dutra) [ Thu May 30, 2002 8:43 pm ] |
| Post subject: | Re: What's that ratio?? |
: I have a 65 Coronet /6 of course...just in case : you guys have forgotten.I'm pretty irregular : on the internet action. Anyway I don't want : to tear my 8 3/4 rear down...so I have spun : the the tires and driveshaft and counted : revolution until I'm blue. I keep comming up : with 3.33 gear ratio. I've been told they : didn't make a 3.33. Does anyone know what : ratios were offered in 1965 B bodies? Does your 65 rearend have the big nuts holding on the rear break drums? Here is a little known fact, the tapered axle early B-Body rearends came in two sizes 8 3/4 and the six cylinder had a 8 1/4, the housings are the same so the center sections can be swapped. An 8 1/4 came with 3.31 and 2.93 ratios. If that is not it, I would guess it's a 3.23, 1/10 turn is a little hard to see. DD |
| Author: | Trysix [ Fri May 31, 2002 8:48 pm ] |
Doug, I do not have nuts holding the rear drums on. I based my assumption that it was a 8 3/4 axle, on the fact that it was a ten bolt - welded cover-rear end housing with the physical measurements of a 8 3/4 of that year model B body. I do know that the ID of the outer seal is 1.875. Some performace gear manufactures speak of two casting numbers but I can't find any natching #'s and there is no tag. The axles are held in buy a nut which requires end play adjustment. Any Ideas? Thanks Again, David/Trysix Quote:
Does your 65 rearend have the big nuts holding : on the rear break drums? : : Here is a little known fact, the tapered axle : early B-Body rearends came in two sizes 8 : 3/4 and the six cylinder had a 8 1/4, the : housings are the same so the center sections : can be swapped. : : An 8 1/4 came with 3.31 and 2.93 ratios. : If that is not it, I would guess it's a 3.23, : 1/10 turn is a little hard to see. : DD Soupitup@msn.com |
