| 75 Dart noise in rear. https://slantsix.org/forum/viewtopic.php?t=3700 |
| Author: | James [ Sat Jun 01, 2002 11:21 am ] |
| Post subject: | 75 Dart noise in rear. |
I have a stock 75 dart I have noticed a noise, kind of a squeak in the rearend over the past few weeks. Today I was out on the highway and suddenly at road speed the car started to lose power and then pick back up, when I let off the gas there was a bad rumble in the rearend. Any advise as to what to check first would be greatly appreciated. I have checked the oil in the rearend and it is fine, but I don't know what to do next. Thanks James jsbgraphics1@netzero.net |
| Author: | Mark [ Sat Jun 01, 2002 5:17 pm ] |
| Post subject: | Re: 75 Dart noise in rear. |
: I have a stock 75 dart I have noticed a noise, : kind of a squeak in the rearend over the : past few weeks. Today I was out on the : highway and suddenly at road speed the car : started to lose power and then pick back up, : when I let off the gas there was a bad : rumble in the rearend. : : Any advise as to what to check first would be : greatly appreciated. : : I have checked the oil in the rearend and it is : fine, but I don't know what to do next. : : Thanks : James Sounds like a bad wheel bearing to me. mwhiteho@hotmail.com |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Jun 02, 2002 7:38 am ] |
: I have a stock 75 dart I have noticed a noise, : kind of a squeak in the rearend over the : past few weeks. Today I was out on the : highway and suddenly at road speed the car : started to lose power and then pick back up, : when I let off the gas there was a bad : rumble in the rearend. : : Any advise as to what to check first would be : greatly appreciated. : : I have checked the oil in the rearend and it is : fine, but I don't know what to do next. : Thanks : James Jack the car up and remove the drive shaft. Now you can inspect the u-joints and rotate the readend around by hand to be sure the problem is back there. If the rearend seems tight or "crunchey", pull off the inspection cover and/or the axle shafts for a look, or just start looking for a replacement unit. DD |
