| slant six swap. https://slantsix.org/forum/viewtopic.php?t=3702 |
| Author: | Abodynut [ Sat Jun 01, 2002 6:03 pm ] |
| Post subject: | slant six swap. |
Hello. I have some questions regarding swapping a slant six. I have a 1975 Dart with lots of miles on it and the original slant six is tired. I also own a 1969 Valiant 100 with 58,000 miles on it and is going throuugh a small block swap. The six in the Valiant says super six on the air cleaner ( IT IS A 1 BBL. ). I have been doing some homework on the 225 and figure the 69 motor to be at about 110 hp. I also understand that the slant went through a tail spin in hp going from the 110 range to the 80 hp range between 73 and 76 if I did the math right? i figure the 110 hp motor with the addition of a 2 bbl super six setup and a set of splitfire plugs and wires should give me about 45 more hp than the 75 motor had and should make my Dart fly. The questions are besides the different K frame is there any other surprises in store on this swap and how can I tell if this is a 225 motor and not a 170? Is there any marks on the motor to tell me the size? miehle@msn.com |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Jun 02, 2002 7:59 am ] |
| Post subject: | Re: slant six ID. |
: besides the different K frame is there any : other surprises in store on this swap and : how can I tell if this is a 225 motor and : not a 170? Is there any marks on the motor : to tell me the size? The ID numbers are stamped on the engine block and cast into the side of the engine block. Go to this article for more info. DD <A HREF="http://www.slantsix.org/articles/sa-franks-book/pg2.jpg">http://www.slantsix.org/articles/sa-franks-book/pg2.jpg</A> |
| Author: | Chuck Rivers [ Mon Jun 03, 2002 1:40 pm ] |
| Post subject: | Re: slant six engine size |
For engine size, also check the length of the short water pump hose. A 225 or 198 has a 3" hose, the 170 has a 2" hose. Chuck Quote:
: : The ID numbers are stamped on the engine block : and cast into the side of the engine block. : Go to this article for more info. : DD : : <A HREF="http://www.slantsix.org/articles/sa-fra ... pg2.jpg</A> webmaster@omnipages.com |
