| K-H Brake Question https://slantsix.org/forum/viewtopic.php?t=37071 |
| Author: | 66aCUDA [ Fri Sep 11, 2009 6:06 pm ] |
| Post subject: | K-H Brake Question |
Does anyone have the bearing numbers and seal number for a K-H spindle. I want to order everything before I tear them down. NAPA only has the 9 & 10 inch listed no Disc. Thanks, Frank |
| Author: | HyperValiant [ Fri Sep 11, 2009 8:19 pm ] |
I dont have the part numbers but ,I have never had a problem getting bearings by specing them for a 69 383 B'cuda.I got Timken bearings a Autozone,but they were listed as 11 inch brakes not defined as disks. HyperValiant |
| Author: | 66aCUDA [ Sat Sep 12, 2009 5:14 am ] |
Ok So the 11 inch brakes is the disc. I tried to go the Duster route(72) and it called out 11" as being different it was like a BR1 instead of a BR4. Are the seals the same? Frank |
| Author: | HyperValiant [ Mon Sep 14, 2009 8:48 pm ] |
Frank, Im not sure about the seals but didnt have any problem getting them a couple of years ago. HyperValiant |
