It is currently Sun Nov 29, 2026 9:46 pm
PostPosted: Tue Sep 15, 2009 11:00 pm
well tonight me and THOR got my valiant back into shape. for real this time. turns out it was a combination of miss adjusted valve lash, coil being over volted (was getting 14v :shock: ) and i replaced my voltage regulator. dash gauge needle was shaking like it had Parkinson's. after that, an idle adjustment and timing adjustment and she purrs like a kitten. so HOPEFULLY the valiant chronicles are now over. and i can finally start prettying up the car a little bit.
PostPosted: Wed Sep 16, 2009 11:17 am
Sounds like a cracked head if it's coming up between the valves with the cover off. Time to do a pressure test on the cooling system and a compression test.
PostPosted: Wed Sep 16, 2009 5:35 pm
ill get that going next couple days. any other ideas that it could be?
