| Kelsey Hayes Rotors https://slantsix.org/forum/viewtopic.php?t=37114 |
| Author: | Jester [ Tue Sep 15, 2009 12:50 pm ] |
| Post subject: | Kelsey Hayes Rotors |
My old rotors were warped and too thin to machine, so I went looking for new rotors. None of the local parts stores lists them as it's a discontinued item, so I had to order these ones: http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem= Centric's I believe, are they any good? |
| Author: | Shaker223 [ Tue Sep 15, 2009 1:35 pm ] |
My local store had them 2 years ago for $26 each. I can check if you like. They are only ok. They have a little warpage. I have not been able to find a rotor in the past year at the local stores that wasn't mfg in china. Pads were still USA. |
| Author: | Jester [ Tue Sep 15, 2009 4:18 pm ] |
They're on the way, possibly next week sometime... Until then, the beast is out of commission. |
| Author: | vynn3 [ Wed Sep 16, 2009 5:29 am ] |
Let us know what you think of them when they arrive. |
| Author: | Jester [ Sat Sep 26, 2009 6:44 pm ] |
Got the rotors via UPS the other day... Whatever brokerage fees are, it's a scam anyways, the rotors seem to be of decent to good quality. A real pain in the ass to remove the old rotors from the hubs and re-install the wheel studs, but a couple hours later and I'm finished the install. Haven't test driven the car yet, but will update after some spirited braking and water sessions, to see if they warp easily. |
| Author: | 66aCUDA [ Sun Sep 27, 2009 4:39 am ] |
Jester were these stamped as to country of origin? I was told a year ago that they were made in Canada. Frank |
| Author: | Jester [ Sun Sep 27, 2009 10:09 am ] |
Not sure, but the caliper is thumping against the hub when I corner, so I'll have a look today when trying to fix that |
| Author: | Jester [ Sun Sep 27, 2009 11:30 am ] |
Couldn't find a stamping on the actual rotors, but they were purchased from R1 Concepts and said "replaces Centric xxx.xx". I pulled the R1 Concept sticker off and the box is stamped "Made in China" |
| Author: | 66aCUDA [ Tue Sep 29, 2009 5:04 pm ] |
Oh well. Maybe they will last. Frank |
| Author: | Jester [ Wed Sep 30, 2009 12:46 am ] |
they seem pretty stout. We'll find out, I guess. |
| Author: | slantfin [ Sat Oct 03, 2009 3:07 am ] |
I got some from Autozone that were cheap; made in China. They look cheap. |
| Author: | Jester [ Sat Oct 03, 2009 12:57 pm ] |
I'll give a rotor update in the next few month to see if they warp. Next brake job, I'm going with '73+ setup, even if the braking isn't as good, at least those parts are readily available at my local parts store. |
