| Hard Shift https://slantsix.org/forum/viewtopic.php?t=37176 |
| Author: | jar84203 [ Sun Sep 20, 2009 4:48 pm ] |
| Post subject: | Hard Shift |
When I shift my transmission into gear, there is a loud metallic clunk and the vehicle jumps forward or backwards. What could be the problem? Thanks |
| Author: | SlantSixDan [ Sun Sep 20, 2009 5:38 pm ] |
What speed is your engine running when you notice this? |
| Author: | jar84203 [ Sun Sep 20, 2009 5:54 pm ] |
Not even moving...when shifting from park or neutral. |
| Author: | SlantSixDan [ Sun Sep 20, 2009 6:19 pm ] |
Re-read my question to you and try answering again, please. |
| Author: | adiffrentcity [ Sun Sep 20, 2009 6:19 pm ] |
What RPM is the engine at(hopefully at idle?), not vehicle speed. EDIT: Jinx dan! |
| Author: | jar84203 [ Sun Sep 20, 2009 7:15 pm ] |
Sorry...500rpm, the stated idle speed in the factory service manual. |
| Author: | SlantSixDan [ Sun Sep 20, 2009 7:25 pm ] |
I was thinking maybe we were talking about a situation where the engine was running on the fast-idle cam after a cold start; under that condition a hard engagement is normal. But if you're getting a lurch/bang even when the engine's warm, at that very low idle speed, then something's the matter — I'm thinking a possible problem in your torque converter. |
| Author: | jar84203 [ Tue Sep 22, 2009 2:08 pm ] |
I pulled the driveshaft out and the bang went away and I also noticed that the transmission yoke spins in neutral. Is this normal? |
