need help!
https://slantsix.org/forum/viewtopic.php?t=37201
Page 1 of 1
Author:  67plymouth [ Tue Sep 22, 2009 6:17 pm ]
Post subject:  need help!
i just recently purchased my 67 barracuda /6 about a month ago. i changed the radiator hoses and thermostat well added one more like it, it didnt have one in there, so i was trying to purge the air and notices fizzing in the coolant so i decided to change the head gasket. i took everything apart rocker shaft, pushrods and cleaned everything and today i put it back together i torqued everything and started it up without the valve cover and it would start up but would die if i let go of the gas, i checked the rocker assemblies and noticed some of the pushrods loose, i did rotate the fan while the head was of would that have had anything to do with it?? im new to this site and i would really appreicate the help thanks
Author:  ceej [ Tue Sep 22, 2009 6:25 pm ]
set the valve lash, then try again.
Author:  SlantSixDan [ Tue Sep 22, 2009 6:31 pm ]
Welcome on the board. You obviously have some experience turning wrenches; that's good. You will want to pick up the three books described in this thread as quickly as you can, to get you up to speed on what to look at (and how to look at it) in what order to diagnose and fix whatever problems may arise. Your "won't idle" problem could be as simple as your having left the PCV valve plugged into the valve cover…and left its hose wide open to the air. That'll create a huge vacuum leak and yeah, the engine won't idle. Remove the PCV valve from the valve cover and put it back in the end of the correct hose and see if it'll idle then. Tune-up parts and technique suggestions in this thread. You'll want to follow the valve adjustment procedure.
Author:  67plymouth [ Tue Sep 22, 2009 6:52 pm ]
thanks for the help i took the pcv valve from the valve cover and connected it to the hose and solved and now it stays on yay! well its getting kinda dark now so ill adjust the valves tomorrow. well ill keep you guys updated and ill try and get some pictures of my car too thanks again i really appreciate it
Author:  slantfin [ Tue Sep 22, 2009 7:43 pm ]
Another case of SlantsixDan magic!
Author:  ceej [ Tue Sep 22, 2009 7:59 pm ]
goodness gracious.
Author:  walpolla [ Tue Sep 22, 2009 8:34 pm ]
Praise the Great Slanted One! :bow:
Well picked, Dan.
regards,Rod :D
Author:  67plymouth [ Wed Sep 23, 2009 9:32 am ]
well just got the valves adjusted and seems to be running fine but it still seems to over heat..... ive changed all the hoses and added a 180 thermostat so i guess next ill have the radiator flushed
Author:  65Dodge100 [ Wed Sep 23, 2009 9:48 pm ]
Don't forget the water pump if you haven't checked for flow yet.
Author:  67plymouth [ Sat Sep 26, 2009 10:52 am ]
yesterday i checked the the temperature from the coolant with a thermomether and compared it to the guage inside the car and it seemed to be off i let the car run for a while and the thermometer never went past 185 degrees and the guage iside was all the way up to the HOT. anyways i ordered a temp sensor should be here today
Author:  wjajr [ Sat Sep 26, 2009 12:30 pm ]
Welcome aboard 67plymouth,
You did install the spring end of the thermostat in the head, and not facing outwards in the housing? Don't ask why I came up with that one... Lets just say I still have a red palm print on my forehead.
A little 3/32 drill hole positioned at 12 o'clock on the outer thermostat flange helps bleed off air when refilling cooling system.
