| Performance/Economy, 4bbl or 2bbl? https://slantsix.org/forum/viewtopic.php?t=37218 |
| Author: | plymouthfury [ Thu Sep 24, 2009 7:14 am ] |
| Post subject: | Performance/Economy, 4bbl or 2bbl? |
I acquired a rebuilt '79 model slant 6 motor recently...I'm thinking about swapping the slant 6 out in my '75 Scamp with this one, but I'm not sure what intake/exhuast I should use. The block was bored .040 over and has all new internals. w/ documentation. The motor has "Clifford" slant 6 performance parts on it. Aluminum 4bbl intake w/ Holley 650 3-3 exhaust headers Aluminum ribbed valve cover. I was told the cam is a Comp Cams mild lift "RV" cam installed for torque... Listed as # JP102251380 on the paperwork. I havent been able to find any specs with that model or number. Any help? I also got a hold of a complete Super-Six setup. What would be the best combination for the best overall performace/economy? Is the 4bbl asking too much? Thanks |
| Author: | oldblue [ Thu Sep 24, 2009 7:24 am ] |
Since the motor is out,check the specs on camshaft yourself.Do you have a degree wheel and dial indicator? |
| Author: | 66aCUDA [ Thu Sep 24, 2009 7:31 am ] |
May me MP instead of JP. MP is Mopar Proformance. Frank |
| Author: | oldblue [ Thu Sep 24, 2009 11:16 am ] |
Lots of info on this site.http://cars.rasoenterprises.com/Carb-Quadrajet.htm |
| Author: | 6shotvanner [ Thu Sep 24, 2009 4:27 pm ] |
I'm going out on a limb here and say the 650 Holley is Way to much carb. I personaly would either find a smaller 4b carb or do the SuperSix(perfered option) and see how it plays out.I'm running the Clifford pieces on mine with a 500 Eddy carb and a Comp RV cam(264H) and while not runnng fat it is a waste of 'extra' carb.I'll be converting to SuperSix this winter and saving the 4b setup for a future build that can use it.Mine are all running 833od trans and with afore mentioned setup best I've gotten is 17mpg combined,it's not a tire burner/neck snappin set up but it does PULLLLL real good.Good luck |
| Author: | coconuteater64 [ Fri Sep 25, 2009 8:19 am ] |
I'm running a 350 cfm Holley 2300 and it pulls like a freight train. I like it. Of course, your results may vary. |
| Author: | plymouthfury [ Sat Sep 26, 2009 11:16 pm ] |
So would running split headers with the 2bbl be a wise option? |
| Author: | Dart270 [ Sun Sep 27, 2009 7:16 am ] |
No problem there. 350 2bbl is probably your best bet. Lou |
