It is currently Mon Nov 30, 2026 4:45 am
 Post subject: NOS Distributor PM
PostPosted: Thu Oct 01, 2009 1:56 pm
I have a NOS distributor from Oldparts Northwest that I will be installing along with a HEI conversion, it was from a mid 70's Charger / slant six.
Seemed to be a good choice for the D-150 I am working up.
Question on the distributor,, it is definitely new,, and the center shaft turns but is really stiff,, since this is a "new 40 year old part",, do you recommend any maintenance / lubing be done on the distributor prior to install?
thanks
PostPosted: Thu Oct 01, 2009 3:42 pm
Sounds like it's gummed up.
I'd lube it. :wink:
Even take it apart if I could.
PostPosted: Thu Oct 01, 2009 4:42 pm
Probably no need to disassemble; a shot of light oil sprayed at each end of the main shaft plus the governor shaft under the rotor, then a few turns back and forth, ought to have it spinning easily.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 4 guests
