| A-904T identification https://slantsix.org/forum/viewtopic.php?t=37333 |
| Author: | Reed [ Thu Oct 01, 2009 9:45 am ] |
| Post subject: | A-904T identification |
Is there a quick and easy way to determine if a transmission is an A-904T with the wide ratio gearset as opposed to an A-904 if the transmission is just sitting out loose? Thanks. |
| Author: | Shaker223 [ Thu Oct 01, 2009 10:33 am ] |
I don't know if there is an easy way but most of the 80's lock up transmissions have the low gearsets (Fifth Ave, Fury, Imperial...etc) |
| Author: | SlantSixDan [ Thu Oct 01, 2009 4:48 pm ] |
You could read and post the trans number stamped into the kickdown-side trans pan rail... |
| Author: | Reed [ Thu Oct 01, 2009 4:58 pm ] |
Quote: You could read and post the trans number stamped into the kickdown-side trans pan rail...
True, but I need to know so I can spot one to buy in a boneyard.
| Author: | 6shotvanner [ Fri Oct 02, 2009 2:23 pm ] |
Can anyone decode this trans #? 4130413 6529 1068 |
| Author: | Shaker223 [ Fri Oct 02, 2009 3:09 pm ] |
Looks like it is from a 1979. http://www.mymopar.com/downloads/transguide.pdf I have a 79 service manual and it still shows the standard gear ratios (no low gear sets avail): 2.45 first 1.45 second 1.00 third 2.21 reverse |
| Author: | 6shotvanner [ Fri Oct 02, 2009 3:15 pm ] |
Thanks,didn't want to offer it up to Reed if it wasn't what he was after. |
| Author: | Reed [ Fri Oct 02, 2009 3:24 pm ] |
Hey, thanks for thinking about me though! |
