| Timimg https://slantsix.org/forum/viewtopic.php?t=37336 |
| Author: | Herr Otto [ Thu Oct 01, 2009 11:23 am ] |
| Post subject: | Timimg |
Now that I have spark and the slant 6 is running , I want to time it. I have adjusted the valves set the dwell but I am unable to get it timed to the exact spec. I can come close but not exact. If I remove the distributor and rotate it clockwise a tooth I still can not get it exact. If I remove the distributor and rotate counter clockwise same problem. I can get it within 10-15 degrees either BTDC or ATDC but not to 2.5 -5 BTDC as required. The timing mark is not wandering. Thank you, Otto |
| Author: | hantayo13 [ Thu Oct 01, 2009 12:29 pm ] |
there is a bolt on bottom of distributor that allows more adjustment.... keep on roddin' |
| Author: | Herr Otto [ Thu Oct 01, 2009 4:57 pm ] |
Thanks for the reply. Are you saying there is an addittional bolt besides the one on the block? Thanks, Otto |
| Author: | Reed [ Thu Oct 01, 2009 5:01 pm ] |
Quote: Thanks for the reply. Are you saying there is an addittional bolt besides the one on the block?
Yes.Thanks, Otto Quote: there is a bolt on bottom of distributor that allows more adjustment....
| Author: | Herr Otto [ Thu Oct 01, 2009 5:22 pm ] |
I forgot to disconnect the Vacuum advance. I will try again tomorrow. |
| Author: | slantsixlancer [ Sat Oct 03, 2009 6:29 am ] |
HA done that once or twice..did it change when un pluged..I find some times it dont.. |
| Author: | Reed [ Sat Oct 03, 2009 10:49 am ] |
Herr Otto, here is a picture of the bolt on the bottom of the distributor:
| Author: | ESP47 [ Sat Oct 03, 2009 11:05 am ] |
Quote: HA done that once or twice..did it change when un pluged..I find some times it dont..
I've never found a difference in the timing when plugged or unplugged.
| Author: | Aggressive Ted [ Sat Oct 03, 2009 1:48 pm ] |
ESP47, Quote: I've never found a difference in the timing when plugged or unplugged.
Then your vacuum advance diaphragm is ruptured or stuck! Get a new one so you can get better mileage and engine performance. Your motor must be pretty sluggish and flat, not punchy......When my pod kicks in it feels like a sling shot!
| Author: | dakight [ Sat Oct 03, 2009 2:32 pm ] |
The distributor is hooked to ported vacuum; at idle it *should* see zero vacuum and have no effect on timing. However, it is best practice to remove and plug the distributor vacuum line while setting the initial timing. |
| Author: | Herr Otto [ Sat Oct 03, 2009 2:36 pm ] |
Disconnected the Vacuum advance and plugged and also found the bolt beneath the distributor and loosened it up a bit. I was able to set the timing now . Thank you all for your help. Otto |
