| NOS Distributor PM https://slantsix.org/forum/viewtopic.php?t=37337 |
| Author: | DadTruck [ Thu Oct 01, 2009 1:56 pm ] |
| Post subject: | NOS Distributor PM |
I have a NOS distributor from Oldparts Northwest that I will be installing along with a HEI conversion, it was from a mid 70's Charger / slant six. Seemed to be a good choice for the D-150 I am working up. Question on the distributor,, it is definitely new,, and the center shaft turns but is really stiff,, since this is a "new 40 year old part",, do you recommend any maintenance / lubing be done on the distributor prior to install? thanks |
| Author: | emsvitil [ Thu Oct 01, 2009 3:42 pm ] |
Sounds like it's gummed up. I'd lube it. Even take it apart if I could. |
| Author: | SlantSixDan [ Thu Oct 01, 2009 4:42 pm ] |
Probably no need to disassemble; a shot of light oil sprayed at each end of the main shaft plus the governor shaft under the rotor, then a few turns back and forth, ought to have it spinning easily. |
