put a slant six in place of 318
https://slantsix.org/forum/viewtopic.php?t=37345
Page 1 of 1
Author:  jim milewski [ Fri Oct 02, 2009 8:07 am ]
Post subject:  put a slant six in place of 318
my truck needs an engine, an 89 Ram pick up, how difficult to put a six where the 318 was, it is a 4 speed 4wd tbi. I had a slant six back in the eighties and really liked it, I think it would be a hoot to have one again, points and carb like the old days
Author:  Reed [ Fri Oct 02, 2009 8:47 am ]
Basically you would need to get a different transmission and then find a truck with a slant six and get essentially everything in the engine compartment- motor, mounts, radiator, exhaust line, carb, fuel line, etc... You might run into problems if your truck has an in tank fuel pump as well.
The bigger problem would be passing emissions.
My advice would be to simply buy an older truck that already has a slant six in it.
Author:  Karasik87 [ Fri Oct 02, 2009 4:32 pm ]
Why would he need a new radiator? You can get hose in any configuration to match any neck to any neck. And the v8 radiator should be able to handle a /6.
Author:  Reed [ Fri Oct 02, 2009 4:44 pm ]
He might not. But the point is it is lots of effort and probably won't pass emissions.
Author:  slantfin [ Sat Oct 03, 2009 4:59 pm ]
Maybe you can find someone to swap trucks with you. Some folks like them V8 engines for some reason.
