It is currently Mon Jun 01, 2026 6:37 pm
 Post subject: Rebuild Fuel Pump
PostPosted: Thu Oct 01, 2009 6:37 pm
I'm pretty sure my fuel pump is dying because there's gas in my oil and I found this thread about rebuilding a NOS pump, but do you think it's possible to rebuild my current one or do I need to buy a new pump first? Thanks
PostPosted: Thu Oct 01, 2009 7:37 pm
Your pump has likely been replaced at some point. The onlu rebuildable pumps I've seen have a series of screws around their circumference that allow access to the diaphragm. If the car is pretty much stock, just go out and buy a new one. I've had good luck with Airtex branded (read: BOXED) pumps.
-James
PostPosted: Thu Oct 01, 2009 7:44 pm
Ok, thanks James
