| Buzzing speedometer https://slantsix.org/forum/viewtopic.php?t=37376 |
| Author: | Reed [ Sun Oct 04, 2009 11:14 am ] |
| Post subject: | Buzzing speedometer |
What causes a speedometer to make a buzzing noise as you drive? THe buzzing increases with speed, so I assume it is tied to the rotation of the speedometer cable and the gears inside the speedometer. Can I take it apart and lube something or tighten something up to make it go away? This is on a 83 Dodge van. |
| Author: | dakight [ Sun Oct 04, 2009 1:06 pm ] |
Try lubricating the cable. Also inspect the cable housing for kinks and dents where the inner cable might be binding. |
| Author: | Reed [ Sun Oct 04, 2009 1:11 pm ] |
Thanks! I will get a tube of graphite and lube the cable. |
| Author: | slantzilla [ Sun Oct 04, 2009 5:23 pm ] |
Vaseline will work too. What you have is the infamous "Chrysler buzz". |
| Author: | Reed [ Sun Oct 04, 2009 5:34 pm ] |
Thanks big D. I'll give the Vaseline a try too. |
