| off topic https://slantsix.org/forum/viewtopic.php?t=37477 |
| Author: | robert garner [ Mon Oct 12, 2009 9:36 am ] |
| Post subject: | off topic |
Can the HEI upgrade used on our Slants be used on a 83 ford 302? If so How? Dizzy and ecu or is there an all in one option? Been searchin' all AM no luck Thanks robert |
| Author: | SlantSixDan [ Mon Oct 12, 2009 10:07 am ] |
I can think of no reason why you can't use an HEI module to replace the failure-prone Ford module. The HEI module should work just fine with a Ford electronic distributor and coil. |
| Author: | Reed [ Mon Oct 12, 2009 10:15 am ] |
Yes! http://www.bronco.com/cms/node/25 ![]() ![]() I plan to do this to my 84 Ford van eventually. |
| Author: | Charrlie_S [ Mon Oct 12, 2009 2:33 pm ] |
I'm pretty sure the HEI setup will work with any 2 wire electronic distributer. |
