Choke Problems
https://slantsix.org/forum/viewtopic.php?t=37545
Page 1 of 1
Author:  86slantram [ Sat Oct 17, 2009 4:34 pm ]
Post subject:  Choke Problems
Hello all-
I have an largely unmolested 86 Ram with a non feedback 1945 Holley. I replaced the carb to manifold gasket recently, and since have been having problems with the choke. Initially, I couldn't choke at all, and cold starts were tough and time consuming. I replaced the linkage between the, excuse me if this is the wrong terminology-the idle cam and the thermo thinger in the pyramid on the manifold, and that seemed to remedy the problem...until today. Same thing all over again. Any guidance/advice is greatly appreciated.
Thanks
Josh
86 D100 225 one barrel 4 spd
Author:  Reed [ Sat Oct 17, 2009 4:37 pm ]
Post subject:  Re: Choke Problems
Hello all-
:lol: Good description. Your answer lies in this article: http://www.slantsix.org/articles/choke- ... adjust.htm
Author:  SlantSixDan [ Sat Oct 17, 2009 6:55 pm ]
H'mm. You may have missing or incorrectly-connected linkages, or the choke thermostat — that's the sheetmetal box bolted to the exhaust manifold tower with a rod running up to the top rear of the carburetor — itself may be faulty. Me, I tend to remove the '73-up choke setups and instead install one of the Electric choke kits.
Author:  86slantram [ Sun Oct 18, 2009 7:31 pm ]
Reed- Thanks for the link
Dan- This works for you? I was considering a manual choke run to the cab, but this looks more interesting (and maybe less of a headache)
Author:  SlantSixDan [ Mon Oct 19, 2009 8:47 am ]
No, not at all, but oddly enough, I keep doing it! :lol:
(Yes, it works.)
Author:  86slantram [ Mon Oct 19, 2009 9:35 am ]
Point taken Dan. They say I shouldn't keep hitting my head with this hammer, but what do they know. Thanks for the advice. Would I be correct in assuming that I wouldn't have to pump the gas before cold start up any more if I switched to the electric choke? Is install pretty straight forward?
I found that the linkage on my choke is catching ever so slightly on the sheetmetal housing for the thermostat. I have made the necessary adjustments and everything is working as it should. Thanks again Dan and Reed for you guidance.
Author:  Reed [ Mon Oct 19, 2009 12:51 pm ]
If you go to an electric choke you will still need to pump the gas once (or even only 1/2 of once) to allow the choke to close and the fast idle cam to set.
Author:  slantsixbob [ Mon Oct 19, 2009 7:17 pm ]
just like reed says you wont hardly have to pump at all(one pump or a partial one). i have an electronic choke kit from the link dan provided and mine works great. i dont mind manual chokes myself but i dont mind being efficient on the other hand either. wouldn't be a bad choice to snag one up.
