ported vacuum problem
https://slantsix.org/forum/viewtopic.php?t=37565
Page 1 of 1
Author:  dodgeram86 [ Sun Oct 18, 2009 6:16 pm ]
Post subject:  ported vacuum problem
I got a 7448 holley carb with 64 jets on a stock slant and timed at 10A.
Got 22 vacuum at idle and no leaks but when a use the ported vacuum
it always stalls when putting in to gear. Engine is a 86 with a late 70's distributors and a HEI Setup. It idles good but cant stop it from stalling, maybe carb is to lean with 54 jets. Thanks
Author:  oldblue [ Thu Oct 22, 2009 11:06 am ]
Have you checked the vacuum advance for a leakage?
Author:  dodgeram86 [ Thu Oct 22, 2009 12:52 pm ]
no leaks on the vacuum advance
